URGENT HELP ! Cam belt slipped.
Re: URGENT HELP ! Cam belt slipped.
Post by ScottieJ » Sat Jan 14, 2012 10:44 am
Yeah the cam comes out from the dizzy side of the head :thumbup:
Post by dan_2k_uk » Sat Jan 14, 2012 11:10 am
Hope you get it sorted ok.
jerseyben
Post by jerseyben » Sat Jan 14, 2012 1:00 pm
dan_2k_uk wrote:Hope you get it sorted ok.
Yer me to haha :) ill take a video of my head if i make it to the workshop today to show my rocker arm problem
Ladaman
Post by Ladaman » Sun Jan 15, 2012 12:07 am
ScottieJ wrote:If the cam has seized it must not be getting oil? Is there any chance you put the head gasket on wrong and blocked an oil passage? I've read that its easy to do?
A mate of mine who is very good with the spanners did this, not once but twice with a similar outcome. SO be very careful when putting the head gasket back in. it might look right, but apparently there is an oil feed hole that "could" be covered up.
jerseyben
Post by jerseyben » Sun Jan 15, 2012 11:12 am
Yer cheers for that i am going to make 100% sure as it will be hard to find another head if i screw this one up. the only other thing is that my oil pump has broken in the time it was out of the car but it is unlikely. I need to do a bit more research on the oil system to make sure nothing else is wrong but the only think i have done is take the head off so i am going to go with the head gasket blocking it.
is there any way to check oil is getting there when I re install this other head and fire it up ?
Post by Darrell » Sun Jan 15, 2012 11:19 am
I thought I'd look into this head gasket and from I can see you can't fit it wrong (or is that just me)
Pic from motorfactors - Diagram from workshop manual.
head gasket.jpg (110.71 KiB) Viewed 5621 times
Post by dan_2k_uk » Sun Jan 15, 2012 11:32 am
They can physically be put on 180 deg out. But you would have to be pretty distracted not to notice. I have chucked one on in a hurry then turned around to pick up the head and turned back and realised straight away.
Dan
Post by Darrell » Sun Jan 15, 2012 11:58 am
More diagrams :thumbup:
oil feed.jpg (44.88 KiB) Viewed 5616 times
jerseyben
Post by jerseyben » Sun Jan 15, 2012 4:08 pm
Thanks guys,
the one I ordered previously was off ebay, i matched the engine code but when it came down the whole's for the aligning pins where not big enough so i had to force the pins through to make them bigger, and some of the water ways where slightly out but not much. some had a bridge where my block didnt. so i will check this oil whole to see if i had it lined up ect and check its not blocked.
and this time ill go to Suzuki specialist and buy the gasket locally :)
Post by dan_2k_uk » Sun Jan 15, 2012 5:37 pm
it it is the wrong way round it will stick out of some sides/corners on one side and leave a gap on others.
If it lines up with the outline of the head all the way round its on the right way round.
Dan
