Shop Ideas... Would you be interested in?
Hello everyone,
We are looking at new items for our shop. If you are interested in any of these items, please voice your opinion below and let us know!
The more people like the ideas the more likely it is we will get the stock
Stainless Exhaust Manifolds
We may be able to get stainless 4 into 1 exhaust manifolds. I think the price we are looking at would be a minimum of around £150.
I know that they are hard to get hold of in the UK nowadays, as you can't get Janspeed ones any more, and LA Supertrux and Specialist Leisure don't sell the calmini ones any more!
If there was enough interest, we would be looking at manifolds for 8v and 16v engines, but may also research into full stainless exhaust systems as well.
Re: Shop Ideas... Would you be interested in?
I would be interested in a stainless exhaust with an ID at or greater than 42mm to go on my janspeed manifold on the LJ
LJ80Q
The ID of these is 42mm so you are in luck
you might tempt me for a manifold but I'm not one for commitment!
What if they are basically identical to calmini manifolds?
this one?
http://www.canam4x4.com/en/Application- ... 00Y-S.aspx" onclick="window.open(this.href);return false;
- Tramp
Will it have the attachment for the 'hot air inlet' for sjs with a standard airbox?
As for merchandise in general - what about some mugs? I was Going to have one printedfor myself (for Work) with an SJ on
Dan, yes its basically identical to the calmini one.
Luke, no this one doesn't have the hot air connector. You would have to get the janspeed one for that...
If you look at the janspeed one it looks relatively easy to get it welded on though
Seems like i am a lucky boy ha ha. Mug a good idea too!
LJ80Q
Would these only be for the 1.3 and 1.6s or would there be a 1litre version too?
