Electric fuel pump
justaddmud
Re: Electric fuel pump
Post by justaddmud » Tue Feb 21, 2012 7:39 pm
Pump Posi-Flow Posi-Flow Posi-Flow
Voltage 12v 12v 12v
Earth Neg Neg Neg
Pressure (Psi) 1.5-4.0 4.0-6.0 7-10
Flow:- US Gallons/Hr 25 32 34
Dry Prime
Height in Mtrs 0.3 0.3 0.3
Thread Size nptf 1/8th 1/8th 1/8th
Operating Temperature -40º F to 180° F
Union Size mm
Power Range (BHP) 150 180 200
Retail £ £29.56 £28.91 £31.46
notice the dry prime height, basically needs to be as close to the tank as posible, especially considdering the tank its self is nearly .3m deep anyway
ianedwards
Post by ianedwards » Tue Feb 21, 2012 8:22 pm
Will do that I think, it will only be a bracket and some wires and some pipe which I'm going to replace any way.
Nice one
Ian
Ian. :)
Post by twiss » Tue Feb 21, 2012 11:51 pm
I've got mine in the engine bay underneath where the original airbox was.
Once the fuel is up to the pump, it works fine... but if you leave it for a while the fuel drains back to the tank and it takes a while to start.
I think I will put a 1 way valve somewhere in the fuel line.
Although, we did the same setup on Russ' SJ and that works absolutely fine.
Might be to do with my fuel return hose not being connected though...
rgonzobull
Post by rgonzobull » Thu Feb 23, 2012 8:13 pm
Ive fitted mine near the tank. Works a treat! I didnt connect a fuel return i just sealed the old pipe up
LJ80Q
