hi,
ive been having a little trouble getting the rear drums off, i should have taken them off a long time ago but i let it slide till now. i think there pretty stuck and i have tried freeing them up with a hammer but no luck, ive also tried fitting a puller on there but the bolts in the middle get in the way. im not sure about the ring around the outside with screws holding it on, ive never seen one before so i dont know if it needs to be taken off?
thanks
joe
quick drum question
- ianedwards
- SCUK Addict
Re: quick drum question
u dont need to take the outer ring off, i snapped the screws trying,
after trial and error, this is how i done the 2nd side,
i took the middle nuts off, put the wheel back on
and hit the tire with a big big hammer,
once it started coming off,
took the wheel off and tapped it off,
worked a treat.
Ian
worked a treat.
Ian
Ian.
Ian.
thanks, thats real cool. i did attempt to take the ring off after failing to remove the drum but i didnt manage it because the screws rounded, good thing i dont need to anyway
cheers
joe
cheers
joe
Slide hammer Best thing I have ever made! you can buy them as well though!
Slide hammers are awesome!
im pretty sure there is a slide hammer in work but im not sure how it attatches, i will have to have a look!
From the workshop manual. I made my own though.
- drum puller.JPG (42.34 KiB) Viewed 6233 times
