Problem is it diff or prop shaft
Re: Problem is it diff or prop shaft
Ok and will i have to adjust the timing ?
Not if you have not moved the distributor.
- Leads.jpg (104.96 KiB) Viewed 4191 times
Well thanks to all your helps i have now fitted my 1st clutch many thanks
Wahey, we told you it wasn't that hard!
It will be even easier the next time you do one!
That's my philosophy, once you have done it the first time it's dead easy after that!
