vacuum hose on standard 8v carb
Re: vacuum hose on standard 8v carb
Post by Darrell » Fri Apr 13, 2012 8:53 pm
turbo-tom wrote:tried the vacum on the dizy/ ufo looking thing and it dont work :| :er: :er:
I don't know where the vacuum advance is connected for sure, if it's from the carb and not the manifold you may not have gotten vacuum at idle (sorry for that :oops: ) Never mind Luke has sorted you out :thumbup: . On the 413 there is a bunch of pipes coming off the manifold but I thought the vaccuum advance would be the easiest (wrong). I can't see that pipe C on my manifold, is that pic from a 410 or am I just being dumb :S
Untitled - 1.jpg (113.32 KiB) Viewed 2815 times
Post by Tramp » Fri Apr 13, 2012 11:12 pm
Pipe c is from the weber carb - sorry thats my bad as I know your running a standard carb, I can't remember where it connects to exactly on the original carb, I think it just joins the standard carb body where all the other pipes are,
Post by turbo-tom » Fri Apr 13, 2012 11:54 pm
Tramp wrote:Pipe c is from the weber carb - sorry thats my bad as I know your running a standard carb, I can't remember where it connects to exactly on the original carb, I think it just joins the standard carb body where all the other pipes are,
thanks for all the help guys :D , mr vacuum guage is all fine now in his little holder :smokin:
