transmission brake shoes
phil1511
Post by phil1511 » Mon Apr 23, 2012 5:03 pm
hi does anybody know where i can source a set of brake shoes for the transmission brake on a sj 413 1998 thanks phil
Highlander
Re: transmission brake shoes
Post by Highlander » Mon Apr 23, 2012 5:11 pm
I have a good spare set..
I'm working away from home till next Tuesday but will have a look when I get back and make sure.
Are yours worn? I've never seen any with a lot of wear, maybe they've been stuck on?
phil1511
Post by phil1511 » Mon Apr 23, 2012 6:11 pm
hello no the the brake shoes were not on there when i brought it neither was the brake drum im guessing they took it off because it was stuck on but luckly i still have the drum but no shoes.
Highlander
Post by Highlander » Mon Apr 23, 2012 6:18 pm
So did they replace the drum with a spacer?
I think I actually have the complete unit, backplate/shoes/springs etc minus the actual drum itself
phil1511
Post by phil1511 » Mon Apr 23, 2012 6:43 pm
im not sure what spacer you mean ? could u explain please
and if u do that would be handy if you wont to sell it that is ?? because i dont acctually have the springs or the lever part.
Highlander
Post by Highlander » Mon Apr 23, 2012 6:52 pm
If you look at this pic of an SJ transfer box (this one has PTO fitted) you'll see the handbrake drum on the left side.
In models without the handbrake drum there is a round spacer/pulley fitted instead, similar to the one that the front prop is attached to (bottom of the pic)
Will have a look when I get back and make sure its still there :)
Post by Darrell » Mon Apr 23, 2012 7:01 pm
Seems like you may be sorted :thumbup:
But anyway, the first time I've searched for handbrake shoes and actually found any
Click Here for Ebay Listing
Part numbers are here http://forum.suzukiclubuk.co.uk/vi ... 14/t,4727/
I thought there was only 1 set of shoes for all transfer box handbrakes, but the ebay ad says there's 2
:er:
Post by ROBBIE » Mon Apr 23, 2012 7:32 pm
i got a set somewhere and i know http://www.rhinorays.co.uk/index.htm does them
phil1511
Post by phil1511 » Fri May 04, 2012 12:31 am
hello again i was wondering if u had and luck finding the complete backplate ?
rockwatt
Recommended Trader
Recommended Trader
Post by rockwatt » Fri May 04, 2012 10:28 pm
I've got quite a few full units ! I always save them complete if there in good condition.
£15+p&p complete
And there are 2 different types jap and Spanish.
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
