electric fans
- turbo-tom
electric fans
how easy is it to put one in?/what do i need to do?
1.what do i need?
2.can i put a shuttoff/over ride switch in?
3.something about "balancing"the water pump?
tom
1.what do i need?
tom
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: electric fans
turbo-tom wrote:how easy is it to put one in?/what do i need to do?
1.what do i need?
tom
1. Suitable fan - relay - Thermostatic switch - Control switch - fuse holder - suitable cable - off warning lamp (if wanted).
2. Yes, but I would only fit an off switch as the thermostatic switch will switch it on when needed.
3. The old viscous fan will be removed and the waterpump should be fine (not heard of balancing it)
How easy to fit ?? - quite easy I say. Does depend on what thermo switch/control switch you use.
Re: electric fans
Very easy to fit
Darrell is right with the parts needed.
I removed my viscous fan, did the bolts up evenly then cut the ends off them.
If you are putting in an off switch I would definitely wire in a light... then you wont be driving around with the fan off without realising
- turbo-tom
Re: electric fans
cheers guys i got most of that stuff laying around the workshop appart from the fan and the sender unit , twiss showed me his one he got from fleebay but i cant justiy that much or shall i just bite the bullet , sureley there must be cheaper altenatives , this is one he showed me
Click Here for Ebay Listing
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: electric fans
Well I've just had a long search round and haven't found the same, let alone cheaper. Yes I've found the aluminium fitting for only about £8 but all the threads are 1/8npt to allow you to fit a temperature sender. This is no use as you need a fan switch and the threads are bigger. Fan switches seem to be about a tenner but again you need one to match those correct temperature on/off settings as the one twiss has does.
The cheap option is a capillary fan switch, much cheaper but not such a good fit as they can often leak where the sensor fits... off for a "google" Darrell.
- turbo-tom
Re: electric fans
yeah thats all i have been finding the 1/8npt 8pound ones , sod it if i have to get that one then i will, but for the mean time i shall keep looking , thanks darrel
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: electric fans
Well this is still an option, not a bad price.
http://www.ccw-tools.com/Radiator-Cooli ... 605-25529/
- 25529.jpg (75.06 KiB) Viewed 6911 times
- turbo-tom
Re: electric fans
hmm yeah looks like one option looks too "open" to me though , and plus no ing me i will probably brake it
Tom
Ford Fiesta ST
Ford Fiesta ST
- turbo-tom
Re: electric fans
if iwas to buy the one below , would it matter is i was to cut it into the top or bottom rad hose? , as the tiop hose has my guage sender in
just had a thought that it would have to in the top hose wont it ?
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: electric fans
Yep
