URGENT...somethings jammed!
Highlander
Re: URGENT...somethings jammed!
Post by Highlander » Mon May 07, 2012 1:23 pm
chris71920 wrote:Think I've found the problem. The input shaft has a partially seized uj, it rotates one way but not the other. I've freed it a little but its not loose enough. Can't work out how to get it apart though :(
Hey i thought you said the UJ's were all free!! ;)
The input shafts UJ's can do that, they only have a slight angle of movement whilst in use, so often sieze outwith that range of movement.
Its probably been put back on in a different position so is now trying to move in a direction it never previously did.
chris71920
Post by chris71920 » Mon May 07, 2012 1:25 pm
Where's the best place to get them? And pretty quickly lol....is it just a case of measuring the outside of the bearing cup to determine what size it is?
I thought they were lol its probably the one direction I didn't check :P
Highlander
Post by Highlander » Mon May 07, 2012 1:31 pm
If you're needing to use the car quickly I would just refit it in the original position till you get one
chris71920
Post by chris71920 » Mon May 07, 2012 2:26 pm
It's not my only car so no worries there, but want it for next weekend ideally.
I'm having real trouble getting this joint apart....even following the how 2
Post by ScottieJ » Mon May 07, 2012 2:28 pm
Darrell wrote:There's some info on th UJ's in the "stickies" that suspiciously looks just like the info I put on Difflock years ago :poke:
http://forum.suzukiclubuk.co.uk/vi ... 12/t,2250/
There's generally 2 different sizes 23mm or 25mm cup sizes.
Wasn't me guvnor
:roll:
Post by Darrell » Mon May 07, 2012 3:55 pm
Highlander wrote:If you're needing to use the car quickly I would just refit it in the original position till you get one
Sorry if I'm sounding dumb, but how do you fit it wrong :D
Highlander
Post by Highlander » Mon May 07, 2012 4:07 pm
You can't.... I'm talking bollocks!! :)
Just did myself a drawing to explain it and i'm wrong, it should still turn ok whatever way its facing.
So unless it actually seized or broken I don't think thats the problem
Post by Darrell » Mon May 07, 2012 4:23 pm
Where abouts are you Chris, I have new UJ's sat on the shelf (25mm ones). I only paid a tenner each for mine direct from my works bearing dealer. White box one's that I thought no way, but he assured me they are good and that many of the well known brands re-box them. Well I fitted 4 a couple of years back and they seem fine.
chris71920
Post by chris71920 » Mon May 07, 2012 4:29 pm
I'm in Norfolk, near Norwich. I can't seem to get the old one out, I've managed to remove only 1 bearing cap and that's it. Im actually on the look out for a complete shaft now!
Post by Darrell » Mon May 07, 2012 4:34 pm
Get the heatgun/blowtorch on the bugger, or PM Mike Harris, he's normally breaking a SJ or two.
