spring over axle
spring over axle
Wen u do spring over axle do u have to angle the axle upwards more.if that makes sense
Re: spring over axle
No! This is a common mistake people make.
It destroys the caster angle on the front axle.
On the rear UJs on the propshaft will no longer be in phase and will fail prematurely.
Weld the new SPOA perches on parallel to the existing SPUA perches.
- Highlander
- Can I have a tow
Angle the diff upwards to reduce the angle on the prop/ujs?
No, especially not on the front, it'll throw your steering geometry out.
dont do sprig over nasty mod imo
- Highlander
- Can I have a tow
Great ground clearance for off road though
Cheers.that mite b why the axles that r on it r nakerd
