91 vitara carb engine , not starting. HELP ME
rossb
Post by rossb » Tue May 29, 2012 6:19 pm
right focks i have a 1.6 8v carb engine , i have taken the whole thing out and resealed it all . ive put it back in and connected everything proper. its turning over but not starting , ive double checked the timing and made sure the distributor is set right . ive taken the plugs out to check if they are sparking and they are . ive poured a bit of petrol down the carb and after a few turns all it does is give off a really loud bang.
car was running fine before apart from all the seals leaking, so not sure it could be the fuel pump.
can anyone help with this
Re: 91 vitara carb engine , not starting. HELP ME
Post by twiss » Tue May 29, 2012 6:49 pm
Take the fuel hose off the carb and put the end of it into a container of some kind, then turn the engine over.... if the pump is working it will spray a load of fuel out!!!
Big bang normally means the mixture or timing isnt right... but it doesn't really mean anything if you pour the petrol directly into the carb
rossb
Post by rossb » Tue May 29, 2012 7:33 pm
feel like a total tube just found a bit of metal that resembles a fuel rod , thinking about it i never put it back in when building up lol
Highlander
Post by Highlander » Tue May 29, 2012 8:31 pm
rossb wrote:ive put it back in and connected everything proper
lol or not :hahaha:
Good to hear its an easy fix! :rockin:
rossb
Post by rossb » Wed May 30, 2012 3:11 pm
lol ye or not , ive took the pump off and water came running out . aaaaaaahhhhhhhhhhh
Post by twiss » Wed May 30, 2012 3:25 pm
Oh dear sounds like your hoses might be on wrong?
rossb
Post by rossb » Wed May 30, 2012 4:24 pm
do u think that could be it . mmm theres not much hoses for the water though . took the head off now and bottom end full aswell .
Post by twiss » Wed May 30, 2012 4:34 pm
Oh dear hope you haven't compressed it and bent the valves or anything like that...
If you can get us a pic of your set up it might help...
Post by dan_2k_uk » Wed May 30, 2012 7:43 pm
U would have to have cranked it for a fair while to fill it with water from the carb!
Get some detailed photos up of the hoses to the carb, fuel pump, and inlet so we can see if we can identify whats the wrong way round.
rossb
Post by rossb » Thu May 31, 2012 8:13 am
cool will do that today
