twin battery/ winch
adamsj
twin battery/ winch
Post by adamsj » Tue Jun 05, 2012 9:19 pm
when fitting a winch do u have to have 2 batteries or is 1 ok aslong my trucks running wen I use the winch.and if I have 2 batteries do u have to have split charge or can u put them in a series linked together
Re: twin battery/ winch
Post by Tramp » Tue Jun 05, 2012 11:10 pm
What ever you do don't link them in series (unless you want 24v!) You should link them in parallel which added the current capacity (but not your volts) of your batteries together making them act like a single large battery, split charge is a good idea and is better although it is expensive and you should be alright with just a second battery in parallel with isolators to seperate it from your standard wiring,
chrisj410
Post by chrisj410 » Wed Jun 06, 2012 6:18 am
If you get a decent battery you'll be fine with one mate, I always have the engine running when winching though
adamsj
Post by adamsj » Wed Jun 06, 2012 8:14 am
ok cheers
