New glove box door & lock
b6mfd
Post by b6mfd » Tue Jun 19, 2012 8:41 pm
Iv got a new glove box door to replace my scratched one and it came with a new lock and keys. The door fits, but the lock and the bit that holds the lock is different. Does anyone know if I can get a bit for in the glove box so that the lock will work? Otherwise I will have to stick it back on eBay :(
ianedwards
Re: New glove box door & lock
Post by ianedwards » Wed Jun 20, 2012 1:22 am
Cant you change the new lock for the original one, or are they different?
Ian
Ian. :)
b6mfd
Post by b6mfd » Wed Jun 20, 2012 9:03 am
No the locks are different, and the bit the lock sits in the glove box door.
Existing lock / back of glove box door
Existing catch
Existing catch
New back of glove box door and lock
Post by ROBBIE » Wed Jun 20, 2012 10:44 am
the door top pic is the same as my sammy so wont fit your 410 dash
Post by dan_2k_uk » Wed Jun 20, 2012 10:58 am
My sammy has the lock from the bottom pic glued into the door somehow by the previous owner.
b6mfd
Post by b6mfd » Wed Jun 20, 2012 10:58 am
ok thanks for confirmation mate!
Post by ScottieJ » Wed Jun 20, 2012 11:13 am
:er: try unscrewing that? it's not original on a 410, I think someone has bodged a different lock into the existing glove box ;)
b6mfd
Post by b6mfd » Wed Jun 20, 2012 11:25 am
I wondered if i could replace that bit to make the new one fit, but there seems to be a few bits missing like a black trim that would sit in the circular hole of the glove box / around the lock...and some screws to fit the lock to the door.
I will take that latch bit off and have a gander.....
Post by ScottieJ » Wed Jun 20, 2012 12:17 pm
you don't need to replace it, I'm pretty sure the standard catch just uses the hole behind it.
b6mfd
Post by b6mfd » Wed Jun 20, 2012 12:29 pm
ah ok, so i just need the little black trim that goes around the lock (if they are meant to have one?) and the screws....
