oil seal gone?
oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 9:05 pm
my driver side joint is leaking very fast :lol: typical just after i got my mot aswell , can anyone tell me were to get the correct parts etc and what i need to do i thanks tom...
Re: oil seal gone?
Post by ScottieJ » Mon Jun 25, 2012 9:09 pm
Tom look in the stickies of the section you have posted this question in ;) ill give you a clue, theres a thread call SJ axle info ;)
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 9:11 pm
im sorry and so there is :lol: ,
so the next step is do i do king pin bearings at the same time? , also what do i need...
Re: oil seal gone?
Post by ScottieJ » Mon Jun 25, 2012 9:14 pm
Nah if it ain't broke, don't fix it! Just do the half shaft oil seal :thumbup:
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 9:16 pm
also i can i pull the felt bit out aswell as thats split aswell so is that a whole cv apart job to do ?
Re: oil seal gone?
Post by Darrell » Mon Jun 25, 2012 9:34 pm
You can get away without pulling the wheel bearing apart. Just undo the 4 bolts and remove the wheel spindle.
This may help http://forum.difflock.com/viewtopic.php?p=707407#707407
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 9:40 pm
Darrell wrote:You can get away without pulling the wheel bearing apart. Just undo the 4 bolts and remove the wheel spindle.
sorry but wheel spindle im confused :er: :oops:
Re: oil seal gone?
Post by Darrell » Mon Jun 25, 2012 9:54 pm
Once the brake disc is off you can remove the 4 bolts and take the spindle off complete.
Some driveshafts will pull straight out exposing the oil seal, but I can't remember which ones :oops:
Re: oil seal gone?
Post by turbo-tom » Mon Jun 25, 2012 10:00 pm
ahh i get you know thanks! :mrgreen:
also do you know where the best place is to get the felts and seals etc
Re: oil seal gone?
Post by Darrell » Mon Jun 25, 2012 10:01 pm
I would check for any play on the bearings first, as worn kingpin bearings make the seal leak (although it's just passed an MOT so they should all be good).
