oil seal gone?
- turbo-tom
oil seal gone?
my driver side joint is leaking very fast typical just after i got my mot aswell , can anyone tell me were to get the correct parts etc and what i need to do i thanks tom...
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: oil seal gone?
Tom look in the stickies of the section you have posted this question in ill give you a clue, theres a thread call SJ axle info
- turbo-tom
Re: oil seal gone?
im sorry and so there is ,
so the next step is do i do king pin bearings at the same time? , also what do i need...
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: oil seal gone?
Nah if it ain't broke, don't fix it! Just do the half shaft oil seal
- turbo-tom
Re: oil seal gone?
also i can i pull the felt bit out aswell as thats split aswell so is that a whole cv apart job to do ?
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: oil seal gone?
You can get away without pulling the wheel bearing apart. Just undo the 4 bolts and remove the wheel spindle.
This may help http://forum.difflock.com/viewtopic.php?p=707407#707407
- turbo-tom
Re: oil seal gone?
Darrell wrote:You can get away without pulling the wheel bearing apart. Just undo the 4 bolts and remove the wheel spindle.
sorry but wheel spindle im confused
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: oil seal gone?
Once the brake disc is off you can remove the 4 bolts and take the spindle off complete.
Some driveshafts will pull straight out exposing the oil seal, but I can't remember which ones
- S5002467.jpg (79.31 KiB) Viewed 8774 times
- turbo-tom
Re: oil seal gone?
ahh i get you know thanks!
also do you know where the best place is to get the felts and seals etc
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: oil seal gone?
I would check for any play on the bearings first, as worn kingpin bearings make the seal leak (although it's just passed an MOT so they should all be good).
