410 Dash In Samurai
dcallaghan2011
410 Dash In Samurai
Post by dcallaghan2011 » Wed Jul 11, 2012 6:14 pm
Hi, I was wondering if anyone knew if a complete dash from the later 410's (complete plastic ones) would fit in my sammy as I prefer the round vents that can then be used for the clocks,
Cheers,
Dan
Re: 410 Dash In Samurai
Post by turbo-tom » Wed Jul 11, 2012 7:07 pm
not sure about 410 but i think 413 pretty much fit and they have round vent holes too ;)
dcallaghan2011
Post by dcallaghan2011 » Wed Jul 11, 2012 8:07 pm
Ok thanks for that, the reason I say 410 is I may be able to get hold one from a 410, if not I'll have to look out for a 413 one,
Cheers,
Dan
Post by ScottieJ » Thu Jul 12, 2012 12:52 pm
yes it should but I think the heater pipes might be different and i'm not 100% sure if the clocks fit in the 410 dash? might be able to make them fit though.
dcallaghan2011
Post by dcallaghan2011 » Thu Jul 12, 2012 6:40 pm
Hi, ok, not to bothered about the heaters, I think I would be able to get hold of 410 pipes if it was a problem, if the clocks don't fit how hard would it be to wire in the 410 clocks? Mine doesn't have a rev gauge so shouldn't be to different?
Thanks,
Dan
silverfox
Post by silverfox » Sat Jul 14, 2012 11:32 am
Pictures of Rhino Special 87/175 made.
It's greyish as they all were but I the colour balance on my phone in the rain makes it look blueish (the wall behind it is terracotta).
It has all of the switches + choke, bonnet and heater cables attached.
The medallion on the dash says 87 of 175 made.
There is a small crack on the glove compartment door and the lock missing. I can't find the ash tray at the monent.
Roger.
dcallaghan2011 wrote:Hi, ok, not to bothered about the heaters, I think I would be able to get hold of 410 pipes if it was a problem, if the clocks don't fit how hard would it be to wire in the 410 clocks? Mine doesn't have a rev gauge so shouldn't be to different?
Thanks,
Dan
SJ Dasha.jpg (50.51 KiB) Viewed 7989 times
SJ Dashb.jpg (59.94 KiB) Viewed 7989 times
dcallaghan2011
Post by dcallaghan2011 » Sun Jul 29, 2012 4:28 pm
Hi, bit of an update, got the old dash out today and the 410 one sort of in so far, all the bolt holes to mount it line up nicely but I need to get to heater controls and heater fascia plate from somewhere as they are slightly differently shaped, the 410 one seems to be more curved and a tiny bit longer than the sammy ones, also as ScottieJ said previously the clocks do need a bit of modifying to go on but shouldn't be too difficult, the heater pipes that I am using are the same luckily as I don't need the ones that go to the round vents,
Dan
