Lazy's samurai build
- lazy rambler
- Can I have a tow
Re: Lazy's samurai build
The engine swap is getting there now, the old engine is out, the gearbox has been seperated and pressure washed, just got to put it all together again now.
- DSC01091.JPG (353.91 KiB) Viewed 15651 times
- DSC01092.JPG (4.13 MiB) Viewed 15651 times
- DSC01093.JPG (4.63 MiB) Viewed 15651 times
- lazy rambler
- Can I have a tow
My su manifold turned up today, so I'll be cracking on with the rest of the engine change this weekend
- 2012-09-07 17.51.53.jpg (1.14 MiB) Viewed 15045 times
- Edweird
Nice looking manifold. Is that a Rockwatt? It looks fairly well port matched to me.
- lazy rambler
- Can I have a tow
Yep that is a Rockwatt manifold and it's now fitted with the SU attached.
Also how can I tell if my starter is a skinny one. I've 'offered it up' and looks like it will only just fit. How do I make sure it's the right kind, after seeing ScottieJ's post in another topic (can't remember what one) I'm not too worried if it's not.
From the look of the previous photos when you removed it it looks like a rather fat one to me.
Dan
Dan
Looking at pic DSC01092.JPG I would say thats a fat starter
- lazy rambler
- Can I have a tow
Just measured up for some new pipes to order tonight, getting close now.
This is my current starter.
- DSC01221.JPG (3.59 MiB) Viewed 14987 times
- DSC01220.JPG (4.16 MiB) Viewed 14987 times
Thats a fat one dude.
- lazy rambler
- Can I have a tow
Little bit of an update:
I managed to find a skinny starter on ebay so that solved that problem.
The engine is now in place (well kind of), I am struggling to get the back of the gearbox to line up with the holes in the chassis. It's about 4mm too far back, a bit of brute force and ignorance should fix that.
Manual choke cable and fuel pump fitted, all new hose set fitted.
That's about up to date now. So I'm hoping to be able to fire it up later on this week.
- lazy rambler
- Can I have a tow
Got the engine fully fitted now. We managed to get the engine to turn over but it wouldn't fire. I think a day or so fiddling with the fuel mix should get it firing.
