Distributor being dizzy
SJVanman
Post by SJVanman » Thu Sep 13, 2012 7:25 pm
Ive recently bought a 413 (1.3 litre) samurai van to get back on the road, however the engine is fitted with a distributor from the 410 (1 litre) engine, I think the engine is miss firing, will my engine run ok on this distributor, if not any ideas where i can find a 413 dizzy? thanks
Re: Distributor being dizzy
Post by ROBBIE » Fri Sep 14, 2012 8:49 am
I got a couple in the shed but I'm away until monday
Post by Darrell » Fri Sep 14, 2012 11:41 am
Don't forget your need the coil as well (assuming the 410 coil was fitted as well as the dizzy).
Post by ScottieJ » Fri Sep 14, 2012 12:44 pm
As long as the points are set up correctly and the condenser and coil are fine then it should run fine.
You will get a stronger spark with an electronic dizzy though ;)
SJVanman
Post by SJVanman » Fri Sep 14, 2012 8:26 pm
Thanks for the help, ill check the points and coil and adjust the timing if there not faulty ill look for a new dizzy, and hopefully shell be on the road for when i pass my test, old SJ is better than any Corsa or Clio ;)
