Help fitting SU carb
charger
Post by charger » Tue Oct 09, 2012 10:35 am
Got it out of the box & couldn't work out
How to I bolt an air filter on, was thing about a flat one rather than the stock airbox can it bolt straight on the the carb?
How do you connect the throttle is the bracket part of he carb or do you need to make one
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Help fitting SU carb
Post by ScottieJ » Tue Oct 09, 2012 12:10 pm
You need to either make or buy one of these
Click Here for Ebay Listing
Also rockwatt makes these to attach the carb to the airbox/snorkel
send him a PM and he'll be more than happy to help
http://forum.suzukiclubuk.co.uk/me ... e/u,10483/
charger
Post by charger » Tue Oct 09, 2012 12:41 pm
Cheers for the heads up
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
lazy rambler
Post by lazy rambler » Tue Oct 09, 2012 9:00 pm
Or fit a K&N filter, you can get them from most classic mini parts websites
Now a build in progress
charger
Post by charger » Wed Oct 10, 2012 8:35 am
Yes that's the type of filter that I want can you point me in the right direction to buying one do they fit al mini's?
Once I have that do i just need to give Rockwatt the size & then he can make the part so it will fit the carb?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
fane21
Post by fane21 » Wed Oct 10, 2012 9:47 am
Just wondering when you said you took it out of the box,did you buy it new?
charger
Post by charger » Wed Oct 10, 2012 10:45 am
Was used
will this filter do the job?
http://www.minispares.com/Product.aspx? ... 663&title=
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by ScottieJ » Wed Oct 10, 2012 1:08 pm
charger
Post by charger » Wed Oct 10, 2012 1:47 pm
Awesome thanks, that set up looks like it will save some ££ on a new air box.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
