Help fitting SU carb
Got it out of the box & couldn't work out
How to I bolt an air filter on, was thing about a flat one rather than the stock airbox can it bolt straight on the the carb?
How do you connect the throttle is the bracket part of he carb or do you need to make one
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Help fitting SU carb
You need to either make or buy one of these
Click Here for Ebay Listing
Also rockwatt makes these to attach the carb to the airbox/snorkel
send him a PM and he'll be more than happy to help
http://forum.suzukiclubuk.co.uk/me ... e/u,10483/
Cheers for the heads up
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
- lazy rambler
- Can I have a tow
Or fit a K&N filter, you can get them from most classic mini parts websites
- DSC01095.JPG (337.66 KiB) Viewed 17755 times
Yes that's the type of filter that I want can you point me in the right direction to buying one do they fit al mini's?
Once I have that do i just need to give Rockwatt the size & then he can make the part so it will fit the carb?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Just wondering when you said you took it out of the box,did you buy it new?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Awesome thanks, that set up looks like it will save some ££ on a new air box.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
