Sj410 converting to 5speed gearbox
will i get a great advantage fitting a 5 speed gearbox to my sj410? id like better fuel economy and top speed but will it effect these massively? and are they not as well geared for off roading?
thanks for the help guys!
Re: snorkel and roof. -now gearbox mods?
gearing is as near as makes no difference the same just with an added 5th for cruising.
should save fuel and i guess if the tyres are close to standard size it might increase the top speed a bit.
good luck finding a good one. if you find 2 let me know!
Dan
Dan
You might not get more top speed because of the lack of power from the 970cc but it will lower the rpm at higher speeds. 2nd to 4th are the same ratios in both gearboxes 1st is a tiny bit lower in the 5speed but by hardly anything.
When running 31s on my stock 410 I could never decide if it was worth it or not because of the lack of engine power but with smaller tyres I would say its definitely worth doing.
awsome! although im still undecided then, is it an easy fit? i assume all 5 speeds are from the santanas? so will it go straight in my 1985 410?
cheers
cheers
As your sj is an 85 it should have the later style 4speed I think so a 5 speed should just bolt straight up?
- dazerede
Re: Sj410 converting to 5speed gearbox
I've got a 5 speed gear box in my 410 only cost me 5 pound and it was a easy fit
4” calmini lift kit
4” calmini lift kit
![:) :)](./images/smilies/icon_e_smile.gif)
thanks guys, but il probably leave it for a while due to money, but mainly EFFORT. but your right it probably wouldn't effect top speed which is what i really wanted.
http://www.ebay.co.uk/itm/SUZUKI-SJ-410 ... t_528wt_87
theres one on ebay for £60 inc p&p, i was going to buy it but i think il focus on my snorkel for now.dan_2k_uk wrote:
Somethings up with my phone because that listing doesent come up when I search suzuki sj gearbox!
- turbo-tom
i had a 5 speed in my sj and went back to 4 speed as i never used 5th of road. but i do think it slightly improves the mpg ![:D :D](./images/smilies/icon_biggrin.gif)
Tom ![:) :)](./images/smilies/icon_e_smile.gif)
Ford Fiesta ST![:D :D](./images/smilies/icon_biggrin.gif)
Ford Fiesta ST
dan_2k_uk wrote:Somethings up with my phone because that listing doesent come up when I search suzuki sj gearbox!
170920876860
Click Here for Ebay Listing
