what are these?
Christoff
what are these?
Post by Christoff » Mon Oct 22, 2012 4:15 pm
Two circled vacuum units
The one on the left was used on myold carb, now not in use with the weber (i assume)
the one on the right has a green plug connection and 2 vacuum outlets that have never had any hoses attached
Re: what are these?
Post by Darrell » Mon Oct 22, 2012 6:59 pm
They are "thingy me bob doofas" or
Idle up valve.jpg (81.41 KiB) Viewed 5136 times
Choke opener valve.jpg (51.66 KiB) Viewed 5136 times
Both only used with the standard carb.....
Re: what are these?
Post by Tramp » Mon Oct 22, 2012 10:07 pm
On my weber I just connected the two points together, after all they are at the same vaccum, the weber kit came with some blanks to fit over these, I had an accident with mine due to the timing being wrong & resulted in a big backfire through the inlet manifold which blew the tops off the blanks! So I just fitted the pipe
Christoff
Re: what are these?
Post by Christoff » Mon Oct 22, 2012 10:16 pm
Well mines ok for now but I could do that to make it neater I suppose
Looking at your choke cable you've left lots of wire after the lever which is good incase it frays or for your adjustment. I'm an idiot and I cut it EXACTLY to length.
Re: what are these?
Post by ROBBIE » Tue Oct 23, 2012 9:33 am
Im running a standard carb I disconnected the green electrical plug and broke the vac pipe thingy :oops: so just blanked it off, still runs ok
