Brake light on dash
Crisdolf
Re: Brake light on dash
Post by Crisdolf » Fri Oct 26, 2012 4:24 pm
Had new brushes and bearing fitted to alternator today put it back on and the brake light as gone off ! :hahaha:
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Post by turbo-tom » Fri Oct 26, 2012 5:47 pm
glad you got it sorted :)
Post by Darrell » Fri Oct 26, 2012 7:16 pm
Crisdolf wrote:Had new brushes and bearing fitted to alternator today put it back on and the brake light as gone off ! :hahaha:
That would sound right. The brake fluid warning light comes on with ignition and goes off when the engines started. It earths via the alternator and goes off as soon as the alternator is charging. This being the case your dash light for the alternator should have come on, I assume the bulbs not blown??
Not to worry, you can go and dazzle them dam rabbits now :D
