Said small piece fell out when the gear box hit me. Any ideas?
Will try n get a photo up. Im thinkings its either some sort of bush or spacer. Possibly for a bolt or something
Small steel tube. Approx 1" long 1/4" diameter
Re: Small steel tube. Approx 1" long 1/4" diameter
one of the top dowels that aids mating gearbox to engine poss
if in doubt, FLAT OUT!
- Edweird
trotter wrote:one of the top dowels that aids mating gearbox to engine poss
I thought the same. Where the bell housing bolts to the block some of the bolt holes have these 'dowels', basically a short bit of tube that locates the gearbox on the engine then a bolt goes through the middle of it.
Like this ??????????
- $(KGrHqJ,!p0E63ZpHW!9BO-jEG3WIQ~~60_12.JPG (17.96 KiB) Viewed 5277 times
Just like that
As said gearbox location dowels
- lunapic_135224196792932_6.gif (43.85 KiB) Viewed 5265 times
Cheers for all the help chaps. I was too busy tryin not to get covered in gearbox oil or hit by it as it dislodged to care what it was. Then i wondered how important is it?
