If you see any mistakes please let me know. Incorrect diagrams are worse than none.
Feel free to add any info you have
Clutch bearing Info
Clutch bearing Info
Re: Clutch bearing Info
Early SJ410
- 09269-38001.jpg (52.58 KiB) Viewed 4422 times
- Early 410 clutch.jpg (171.59 KiB) Viewed 4422 times
- Early 410 pilot bearing in crankshaft (2).jpg (161.83 KiB) Viewed 4422 times
- Early 410 clutch bearing.jpg (154.79 KiB) Viewed 4422 times
Later SJ410
- 09269-33001.jpg (52.37 KiB) Viewed 4421 times
- Later 410 clutch.jpg (212.18 KiB) Viewed 4421 times
- Later 410 pilot bearing in flywheel.jpg (136.84 KiB) Viewed 4421 times
- Later 410 & 413 clutch bearing.jpg (119.9 KiB) Viewed 4421 times
SJ413-Sammie
- 09269-33001.jpg (52.37 KiB) Viewed 4420 times
- 413 clutch.jpg (191.38 KiB) Viewed 4420 times
- 413 Pilot bearing.jpg (151.75 KiB) Viewed 4420 times
- Later 410 & 413 clutch bearing.jpg (119.9 KiB) Viewed 4420 times
Bit more --
- Suzuki SJ clutches.jpg (201.85 KiB) Viewed 4372 times
