webber carb probz with snorkle
hamer
Post by hamer » Sat Nov 17, 2012 5:16 pm
Hi guys just fitted a snorkle
used 2" pipe toped with a mushroom head filter
power has droped badly cant get over 30 on the road wer id normally get 50 it keeps boggin out
shall i ditch the webber carb and get a su?
just had the worst day out in it ever lol
ferris
Re: webber carb probz with snorkle
Post by ferris » Sat Nov 17, 2012 5:39 pm
You might be getting carb freeze. I had the same problem with my old weber and snorkal setup. I had to cut a hole in my snorkal pipe so i could connect the hot air feed up.
hamer
Post by hamer » Sat Nov 17, 2012 6:18 pm
Is that the pipe witch gies to manafold and the the head
i have an ooen end on it naw as ut used to be on the filter?
ferris
Post by ferris » Sat Nov 17, 2012 6:36 pm
There is a flexy pipe that attatches to the exhaust manifold and the original air box. It may have been removed when the weber was fitted.
Post by Tramp » Sat Nov 17, 2012 6:38 pm
If it was running fine with the weber before, then you fitted the snorkle and now its it shit I think it may be a problem with the snorkle, id check for kinks or anything that would reduce the diameter and cause reduced flow inside it
hamer
Post by hamer » Sun Nov 18, 2012 10:33 am
The feed was on i removed it wen i put snorkle on
startin to think thats wer the prob is naw
thers no kinks and iv made it as short as possible
i took it all off and ran it with no filter made no diffrence
still bogged
Post by ScottieJ » Sun Nov 18, 2012 12:08 pm
Can you post a pic of your snorkel set up? What I do is run the snorkel off the original air box and seal it all up with silicone sealant. Then I would dissconnect the hot air feed and fit a rubber glove over the hot air feed intake when out offroading to seal it up for wading.
hamer
Post by hamer » Sun Nov 18, 2012 3:09 pm
Its heavly taped up lol
any advise on doing the mixture on carb guys?
2012-11-18 15.04.37.jpg (1.42 MiB) Viewed 7404 times
2012-11-18 12.08.10.jpg (1.51 MiB) Viewed 7404 times
Post by ScottieJ » Sun Nov 18, 2012 4:28 pm
Ermmm an air filter would be a good idea!!!!! if it was running fine before the snorkel I doubt it's anything to do with the mixture. There's not actually a filter in those snorkel tops is there?
Running an air filter is even more important when running a snorkel. I would refit the air box and run the snorkel from there.
hamer
Post by hamer » Sun Nov 18, 2012 5:02 pm
K thanks mate
no ther no filter in ther :(
il sort it after wrk tomoz :)
just conected up the filter with a few mods of the 2" pipe
but it dont bend nice..would 44mm pipe work to join to the existing 2"snorkle pipe as it bends much easyer?
thinkin it will restrict too much air?
