SU Vacuum hole
SU Vacuum hole
I see on posts that some re drill vaccuum pipe hole, my SU has the hole slightly air filter side of body does this still need drilling.
- su.JPG (235.73 KiB) Viewed 4396 times
Re: SU Vacuum hole
Isn't that hole on the bottom of the carb? Normally the vac takeoff is on the top?? Can you take a pic of the vac point on the outside?
Re: SU Vacuum hole
Yes it is the bottom of the carb but it still just (Only Just) air filter sde of the body
Re: SU Vacuum hole
As long as its on the air filter side then it's fine.
This is where the vac take off normally is is yours like this??
- Tramp
Re: SU Vacuum hole
I had an SU that I was going to fit & that was the same with the vac takeoff point in the correct position, you should be fine with that!
Re: SU Vacuum hole
Yes mine is the same as pic 2.
All being well Sunday is the first fire up day !!!!!!!!!!!!!!!!!!!!!!!!!!
