best oil
Re: best oil
It's all down to cost really, mineral oil > then semi synthetic > then fully synthetic.
If your planning on doing lots of miles then fully synthetic has a long service life but I use semi synthetic.
Same with the gearbox it's mineral or semi/fully synthetic. Quite a price difference though. I used synthetic but if you go wading I recommend using mineral oil and change it often (but your not going wading are you, too tidy for that )
I know people put breathers on everything but so often the oil still comes out contaminated.
Same applies to transfer box and diff oils.
Re: best oil
what weight tho?
Re: best oil
Thought I'd posted this before but couldn't find it
So I've re-done it
So I've re-done it
- Oil changes SJ413.jpg (352.11 KiB) Viewed 6690 times
Re: best oil
diff and t box oil is EP90 or ep80/90 i think its called now.
can rememeber the gear box one.
cheapest place for the one litre bottles of comma ep90 is wilkos i found £3 ish when i bought my last lot.
- turbo-tom
Re: best oil
Tom
Ford Fiesta ST
Ford Fiesta ST
- Edweird
Re: best oil
I used EP90 and 10W/40 semi synth
- dazerede
Re: best oil
hell that is cheap gear oil for 3.50 might get my hands on some litres
4” calmini lift kit
4” calmini lift kit
Re: best oil
yep i stocked up when i was in there. think its a fiver in my local
motorfactors. every little bit helps
