SU Carbs
suzuki-rob
Re: SU Carbs
Post by suzuki-rob » Thu Nov 01, 2012 10:04 pm
so it looks like for my 1300 ill need a Bdl needle but still unsure about spring? will it just be a bit of trial and error or has someone done same conversion and know more than what i do.
as for fuel mix i take it this will be the same have a play until its running right.
Re: SU Carbs
Post by ScottieJ » Fri Nov 02, 2012 8:57 pm
The first page of this thread links needles and springs for each engine ;)
suzuki-rob
Re: SU Carbs
Post by suzuki-rob » Sun Nov 04, 2012 6:03 pm
right ive got on to minisport website and i was looking at the hif44 needles and i cant find a bdl needle anywhere ive found a bdk if that's any good. ive got sorted with a new spring a stage one kit red spring
Re: SU Carbs
Post by dan_2k_uk » Mon Nov 05, 2012 6:37 am
trotter
Re: SU Carbs
Post by trotter » Mon Nov 05, 2012 10:29 pm
or make me an offer, i've got a basically new bdl needle and a red spring that was fitted to my old 1300 engine for a whole 10 miles before it went bang :lol:
if in doubt, FLAT OUT!
suzuki-rob
Re: SU Carbs
Post by suzuki-rob » Mon Nov 05, 2012 11:58 pm
how much do you want for full hif44? save me having to set mine up lol
trotter
Re: SU Carbs
Post by trotter » Tue Nov 06, 2012 8:50 am
Haven't got a spare hiff44 just a spare needle and spring.. Setting it up isnt hard it just takes a bit of time while you fiddle with it.
SJ Greg
Re: SU Carbs
Post by SJ Greg » Thu Dec 06, 2012 7:23 pm
hi guys i have brought an su for my samurai i was told to get a bbz needle and yelow spring but reading this that is for the 1600 conversion what will it do/ not do for my lil 1300? also is it possible for some one to send me a link to fitting instructions as i couldnt see the pictures
thanks greg
Re: SU Carbs
Post by Edweird » Thu Dec 06, 2012 7:32 pm
Having the wrong needle and spring means that the piston in the carb won't rise at the correct rate for the engine and the wrong needle means that you'll get the wrong amount of fuel being fed into the engine.
Given the yellow and a BBZ needle are for a 1600, I'd say the piston won't rise fast enough, so you get extra fuel and the thinner needle will give you extra fuel too.
I'm sure someone else will have a link to a tutorial for changing the spring and needle.
SJ Greg
Re: SU Carbs
Post by SJ Greg » Thu Dec 06, 2012 7:45 pm
thanks edweird i can do the sping and needle just not sure on what pipe work etc etc goes where
