In simple terms what oils are required for GEARBOX,TRANSFER BOX AND FRONT & REAR AXLES,Local motor shop says it is the same in all is this right ???
Also how much is required ???
Many Thanks
Oils
Re: Oils
Same in all. And i've just changed mine and i'm damned if i can remember the grade.
Re: Oils
Here it is
Jordi1988 Samurai - Truck Cab & Tray Back - 1.6 8v & HIF44 - Snorkel - Stack Exhaust - PAS, YJs & 33s - Trussed, Gusseted & Pumpkin Capped Axles - 4.3 R&Ps - 4.16 T/Box - Rear Air Locker - Full Float Back Axle & Discs - RCV Front Shafts - X-Eng Handbrake - Custom Fuel Tank
