ScottieJ wrote:Yeah I was just thinking when you said that you only had it for a month that you might not know quite how they should be normally. I think the prop would be ok looking at it in the pics but ill see if I have one anyway for you.
Big bang, lots of bits, no go!
Re: Big bang, lots of bits, no go!
- image_zpsc6dcdfa0.jpg (25.92 KiB) Viewed 4082 times
- rude mechanic.jpg (27.92 KiB) Viewed 4082 times
I meant just the main section, obviously it needs a new slip yoke end.
Suzie is finally back on the road!
After much hunting for the right gearbox, much swearing to get it fitted, and some new shiny heavy duty transfer box mounts she works a treat. It's much quieter than before (I guess that UJ must have been on its way out for a while) and I now have a 5th gear which is a novelty!
Thanks for all the help.
Cheers,
James
Cheers,
James
Nice one glad you got it sorted and found a gearbox, bonus it being a 5 speed
Wow. Missed this the first time round. No cable ties or gaffa tape are gunna fix that!
No wonder you couldnt select a gear!
