1.7 isuzu cluch problem
dandan
Post by dandan » Sun Dec 16, 2012 7:02 pm
after a lil advice i recently bort a sj with the 1.7 isuzu engine in with carlton gear box, but sounds like the release bearing is makeing a hell of a noise it has been replace apparantly befor i bort it so shount be that but he woz saying that there is some sort of spacer that u have to fit between bearing an cluth fork but he dont no if it is the right lenth can any body help
Re: 1.7 isuzu cluch problem
Post by ScottieJ » Sun Dec 16, 2012 8:21 pm
Yes there is a spacer you need to get machined up, my mate had one done for his conversion, ill ask him if he has a drawing or some dimensions.
dazerede
Post by dazerede » Mon Dec 17, 2012 7:41 am
Welcome to scuk we love pics
4” calmini lift kit :)
dandan
Post by dandan » Mon Dec 17, 2012 8:25 pm
cheers m8 an pic would be greate an thanks 4 lettin me on ere :)
Post by ScottieJ » Mon Dec 17, 2012 9:23 pm
Right found a pic of my mates and its 24mm thick he says
He's gonna have a look to see if he has a drawing with other dimensions but here's a pic of it fitted
dandan
Post by dandan » Mon Dec 17, 2012 10:28 pm
sweet that will help loads :) im guna have 2 tack mine appart now see if its got 1 an wot size it is if it has , an how much damage has bin done 2 bearing
dandan
Post by dandan » Thu Dec 20, 2012 8:28 pm
does he no wot the release bearing is out of as mines hydraaulic 1 like that but normal carlton box uses cluch fork type, had a bit of a look and fink it the 1 out of the astra but cant b sure
felstmiester
Post by felstmiester » Sun Jan 20, 2013 9:53 am
The spacer I needed when I done my Isuzu conversion was more like 35mm.
dandan
Post by dandan » Mon Jan 21, 2013 11:05 pm
i guess its just going to b trial and error the, just got pull the box off still see wot size is in it now
felstmiester
Post by felstmiester » Tue Jan 22, 2013 8:20 pm
Well mines a 1.5 td Isuzu so you'll prob be running a different clutch to me. I would more than likely say the release baring is knackered and it hasn't been done recaintly. It's not an easy conversion to do and I can't see someone going to all that trouble and not making 100% sure the spacer was the right length. If its a Carlton box they've got a big hole the opposite side of where the fork goes in. You may be able to get enough acces through that to check.
