my rhs head light has a small hole in it, i need another one, will any headlight do, or are the various years different, they all look the same, but i guess some do not have the adjustment motors.
mine is a 99-2000 model 4u2.
thanks
shaun
vitara headlights
- plugspanner
Re: vitara headlights
they all same swb or lwb vit the only differance is like you say some have the motor for adjustment & some dont
is it driver side you need & with motor ???
- plugspanner
yes it is the drivers side.
i may have to wait until i have fitted the 3in lift i am getting from you, the mot is a bit farther off.
how much inc p+p?
thanks
shaun
how much inc p+p?
thanks
shaun
ive got quite a few headlights i will have to check if any have motors if thats the one you want
will pm you when ive had chance to check through them
- plugspanner
brill, with motor yes,
thanks
thanks
