Pissing oil out big time after new rocker seal
Christoff
Re: Pissing oil out big time after new rocker seal
Post by Christoff » Tue Dec 18, 2012 3:43 pm
I can remove the pipe on top of it and press against a spring with a small screwdriver.
Does this confirm that it's working or could there be a blockage behind it maybe?
Post by ScottieJ » Tue Dec 18, 2012 5:46 pm
You could always stick your mouth on it and suck and blow :lol: it shouldn't let you suck but should let you blow :lol:
Post by dan_2k_uk » Tue Dec 18, 2012 5:47 pm
Could be blocked behind it. Need to whip it out and check it rattles and air can move through it.
Dan
Christoff
Post by Christoff » Tue Dec 18, 2012 5:50 pm
Don't fancy sucking my engine off tbh. Lol
Il try and remove the valve at work.
