Hi and HELP
Hi and HELP
Hi to everyone. I was looking for a small 4x4, and had settled on an Asia Rocsta, until I bid on this, and nobody else did.
It's an F plated 1989 SJ410, with just 51k on the clock. Been dry stored since Feb 06, but has rot in the floor, sills, and seems where the floor meets the inner sill.
I shall have a proper look when I collect it Sunday, but if anyone can give me any advice, I would appreciate it.
I know my way around cars, and I founded and am chairman of www.zastava-yugo.co.uk
- The newest recruit
- SJ410b.JPG (73.86 KiB) Viewed 8515 times
Re: Hi and HELP
Sounds like the usual places for a bit of rust on these, I presume if your into old cars you know how to weld? These aren't to bad to weld up but the panels are quite thin so I'd recommend using .6mm wire.
Everything else is about as to work on as it gets, they are really simple!
Re: Hi and HELP
Hi and thanks for the advice.
Yes, very handy with all welding. I used to restore classic cars for a living.
Re: Hi and HELP
Awesome. well I'm sure you're going to find this easy to sort out then
Dont forget to start a build thread once you get to work on it
Re: Hi and HELP
Might need some help with that. I hate forum's. My brain doesn't seem to work with them, as they are cluttered and disorganised in my head!!! But if you tell me how to do it, I will.
Should be collecting the car on Sunday.
Re: Hi and HELP
Hi and
If you know your way round a car you will have no problem with one of these.
To get a build thread started go to this section http://forum.suzukiclubuk.co.uk/vi ... .php/f,22/
then create a new topic for your thread.
have a look through some of ours to see what we mean by a build thread.
mine is in linked in my signature under "build thread"
Dan
Dan
Re: Hi and HELP
Thanks Dan
Will start one when I collect on Sunday.
Appreciate the help.
Re: Hi and HELP
Thats what we are here for
Re: Hi and HELP
