vitara nuts and bolts
plugspanner
Post by plugspanner » Fri Dec 21, 2012 1:58 pm
any one know what the thread is on the engine block holes are on a 1.6 vitara?
they are not m8, but is suspect metric fine.
just found my steering pump is hanging off and although i have hundreds of bolts none will thread in, the one remaining bolt will not fit any of my nuts either.
hope someone will know
thanks
shaun
Re: vitara nuts and bolts
Post by ScottieJ » Fri Dec 21, 2012 2:06 pm
Yes they are all metric M8x1.25. If you give me some lengths I can send you some, I have 100s of suzuki bolts :thumbup:
plugspanner
Post by plugspanner » Fri Dec 21, 2012 2:38 pm
that is very kind of you, most of mine are much smaller motorbike bolts.
a selection of lengths from 25mm L onwards would be ok
do you want me to pm my address and how much do you want for them?
thanks
shaun
vitara_mad
Post by vitara_mad » Fri Dec 21, 2012 3:01 pm
standard m8 bolts are 1.25
ive also got 1000's of bolts out of suzuki's
try running a tap through the threads to clean them out
