My suzuki needs abit of love HELP !
Re: My suzuki needs abit of love HELP !
It shouldn't start without that wire it's the ignition feed, so fit a fuse in and rewire it.
Chances are your carb is now full of crap as you have run it with no filter (not clever!!!!) so strip the carb and clean it, there is a guide in the DIY section.
also please give your engine a bit of respect, there's really no need to rev it loads with your foot to the floor, all you will do is more harm than good.
if you can get it started then let it warm up, put it in low ratio, don't rev it loads and be really steady with the clutch, slip it if you have to and you'll be able to drive it out of the field.
yer its only the plastic round the outside that melted
Scottie can you just do it for me please the wire bit !!
I'm over 100miles from you Ollie otherwise I would
ahhh okay scottie ive just been on the D I Y section there is only abit about SU and 410 not the 413 engine.
- turbo-tom
i would love to have a feild and a digger woah the things you could make to driver over
Tom
Ford Fiesta ST
Ford Fiesta ST
yer we have never had a digger but me and my mates have made dmr / bmx jumps by hand they are about 6 foot but now the smaller ones that we originally had i just driver over them ha.
http://www.suzukiclubuk.co.uk/diy/15-en ... down-guideOllieSJ wrote:ahhh okay scottie ive just been on the D I Y section there is only abit about SU and 410 not the 413 engine.
Looks like effort that i dont have uggghggh
