Project Bodge
Re: Project Bodge
Post by dan_2k_uk » Sat Dec 22, 2012 6:13 pm
Along with the SU and power steering the rear disc is one of the best mods going. Havent touched mine since they were fitted. Compared to drums even just the maintainance aspect is superb.
Dan
ferris
Re: Project Bodge
Post by ferris » Sat Dec 22, 2012 6:44 pm
Thats good to hear. I have nothing but trouble with my drums. Generally have to take them apart on a weekly basis. Probably due to driving through to much deep water :lol: .
dazerede
Re: Project Bodge
Post by dazerede » Sat Dec 22, 2012 9:56 pm
Looks good ferris
Might do a rear dis conversion on my sj soon
4” calmini lift kit :)
ferris
Re: Project Bodge
Post by ferris » Thu Dec 27, 2012 9:28 pm
Well i made a start on the conversion today. Didn't get much done as i couldn't really be bothered :lol: , but il have a proper go at ot tomorrow.
Stripped it down
Cut the old drum off the half shaft. So as not to damage the bearing.
Then fitted the caliper bracket and the bearing retainer. Had a bit of a problem with the split bearing retainers i bought. As the bearing sticks out the axle about 3mm so the new bearing retainer won't screw back all the way and there is a gap between the axle and the retainer. If i knew this was going to happen i would have cut the middle out the old drum and used that instead, but id all ready cut that up. Think il do that on the other side.
Then cut the middle out the drum to make the other disc holder.
Re: Project Bodge
Post by Jordi » Thu Dec 27, 2012 9:34 pm
Progress is progress bud.
Mine has been slow but getting there. Looks like a tidy job. Are you using front discs and calipers?
Re: Project Bodge
Post by Darrell » Thu Dec 27, 2012 9:51 pm
I've wondered about those split retainers as the normal ones they sell appear to to stepped. I assume these fit flush with the axle while holding the bearing fully in (as they should do).
Re: Project Bodge
Post by Darrell » Thu Dec 27, 2012 10:33 pm
Been "Googling"
It seems to me those retainers are not really stepped, just have a chaffered edge.
It seems the gap would normally be filled with the caliper plate made by Muddyzook.
As your using the front caliper mounts (as many do) you would be better off using the drum backplate cut out.
Sorry for never looking into this before :oops:
Maybe you could cut a spacer plate out , then fit a cut out backplate/retainer next time you do a bearing change.
Having said that, it's not going anywhere with just the washers I suppose :thumbup:
ferris
Re: Project Bodge
Post by ferris » Thu Dec 27, 2012 11:21 pm
Ahh yes that makes sence. Thanks for the info Darrell :thumbup: .
It does seem ok with the washers, just looks a bit bodge. I will use the original drum retainer on the other side, and i will have to change the split one when the bearing next go's. Which probably wont be to long :lol: .
ferris
Re: Project Bodge
Post by ferris » Thu Dec 27, 2012 11:58 pm
Jordi wrote:Progress is progress bud.
Hi Jordi, Yeah using some standard front discs and calipers.
Re: Project Bodge
Post by andyrew » Fri Dec 28, 2012 7:31 am
could you just make a ally spacer out of some 3mm sheet? you could use the plates as a template and just make the hole in the centre a little bigger than the size of the bearing.
