So, I got a little more done today.
the old man's Mr Angry packed up, so i went to borrow one at work, and done some of the heavy rust cutting.
- floor pan support cut away
- Pic_1231_028.jpg (21.4 KiB) Viewed 8300 times
The floor pan support is a little rusted too as you can see in the last picture. This is where the bullbars bolt unto as well, so do you reckon i should fix it, or just hammer it? the rust is only a little bit so...
I started to make a plate to fix the sill end
- the new sill bottom i made up, not yet welded
- Pic_1231_027.jpg (11.36 KiB) Viewed 8300 times
I also found that the sill had acquired some mud over the years through the rusty hole that used to be there
- the inside of the sill
- Pic_1231_029.jpg (10.88 KiB) Viewed 8300 times
this appears to be a breather hole for the sill just behind the cab, should i leave it, or close it off?
- breather hole open
- Pic_1231_030.jpg (12.25 KiB) Viewed 8300 times
- breather hole closed
- Pic_1231_031.jpg (14.14 KiB) Viewed 8300 times
I am also trying to find a carb for it now, and placed a bid on a su carb, model unknown, so we'll c what happens
