Been offered a 1.6 8 valve.
No coil, alternator or starter but i can use 1.3 bits
No fan, it is as simple as redrilling my 1.3 fan isn't it?
Swapping fans
Swapping fans
Re: Swapping fans
Get a electric one much better
Re: Swapping fans
I'd use the opportunity to put an electric one on, then you can knock it off in water?
Re: Swapping fans
Cheers chaps. Not a bad idea. Any one know of a leccy fan that fits?
Re: Swapping fans
Water pump is the same therefore the original fan will bolt straight up!
I would recommend fitting a 1.6 rad
- turbo-tom
Re: Swapping fans
the ebay slim line cheap specials fit the biggest you can get on 1.3 radiator is 14inch as twiss has on on his , or on the vitara 1.6 radiator you can get two 9 inch ones on next to eachother
Tom
Ford Fiesta ST
Ford Fiesta ST
