Which air filter?
duncslow
Which air filter?
Post by duncslow » Tue Jan 08, 2013 9:50 pm
Hi folks, Im in the process of doing a 1.6 vit to 410 conversion and need a new air filter. are the standard 410 paper filters any good, or is it better to fit the more expensive k&n replacement. Do the K&Ns perform any better. any advice welcome. There is going to be a snorkel fitted if it makes any difference.
Regards Chris
trotter
Re: Which air filter?
Post by trotter » Tue Jan 08, 2013 9:53 pm
personally i'd use the standard airbox and hook the snorkel to that.. dont think a K&N makes much diff in a sj to be honest. I've got one fitted direct to my su carb and it works but not really noticed any diff from the standard filter
if in doubt, FLAT OUT!
duncslow
Post by duncslow » Tue Jan 08, 2013 10:14 pm
Thanks for the reply, Im going to use the standard airbox as you suggest, Its just that ive seen k&n replacement filters to go in the airbox, but they are about 45 quid where as the original is about a tenner. I was just wondering if the stock filter and airbox will hold the engine back at all.
regards Chris
Post by ScottieJ » Tue Jan 08, 2013 10:19 pm
I wouldn't ever use a k&n unless its one of their heavy duty filters but then you might as well just use a standard filter. Standard k&ns actually allow te finer particles of dust through, something you don't really want in an offroader that will be used in dusty conditions in the summer.
I would either use the 1.6 airbox or adapt a 1.3 carb top to fit the 1.6 carb then link it to a 1.3 airbox with an ITG filter if they still do them for the 1.3? They are really good filters.
duncslow
Post by duncslow » Tue Jan 08, 2013 10:34 pm
Im using a 1.3 carb top with a 410 air box, Ive had to cut the elbow off the airbox and spin it round a bit to get a better line to pipe it up, So on your advice I will replace the air filter with a decent OE replacement.
Cheers.
Post by ScottieJ » Tue Jan 08, 2013 10:57 pm
You can't just bolt the 1.3 carb top onto the 1.6 carb, you need to add a piece of tube that fits the carb and raises it up a out 15-20mm otherwise it will stop the choke working properly (ask me how I know :lol: ) also I think the 410 airbox will restrict the 1.6 to be honest, in the inlet and outlet are quite small.
Post by dan_2k_uk » Tue Jan 08, 2013 11:28 pm
As the 44mm SU is the carb of choice on the 1.6 it makes sense that everything should be above about 44mm diameter as not to restrict it. Thats how I see it anyway.
