Prop question
felstmiester
Re: Prop question
Post by felstmiester » Sun Jan 13, 2013 4:05 pm
Transfer box end
felstmiester
Re: Prop question
Post by felstmiester » Sun Jan 13, 2013 4:06 pm
Hard to get a pic of it all but.
Re: Prop question
Post by Darrell » Sun Jan 13, 2013 4:13 pm
I'm afraid the alignment looks bad. The prop on mine is also the other way around if this makes a difference. The output shaft should be parallel as possible with the axle input shaft.
Lets wait and see what guys think, who have done this kind of mod.
Here's a pic of mine for comparison.
felstmiester
Re: Prop question
Post by felstmiester » Sun Jan 13, 2013 4:15 pm
Did you weld the new perches parallel with the original ones ???
Yes on the rear axle I did. I made a jig up and replicated it, welded perches on and when I fitted it it came out like this but didn't think it was at to bad a angle. With the front I prept all the stuff put the axle on measured and measured again tacked the perches on then took off and welded so the front props spot on.
felstmiester
Re: Prop question
Post by felstmiester » Sun Jan 13, 2013 4:21 pm
When I originally made this f**k up with the rear axle I looked at another post on here at this pic and thought well mines not as extreme but I see what you mean. Mine is facing up.
dazerede
Re: Prop question
Post by dazerede » Sun Jan 13, 2013 4:22 pm
im not an exspert but that diff does look like he is pointing up a bit
and also i thought the props should be the other way around with the female near the t-box :er:
4” calmini lift kit :)
Re: Prop question
Post by Darrell » Sun Jan 13, 2013 4:26 pm
Not sure what's going on there then :er: Our angles and much different. The propshaft from the transfer box is actually going up :shock:
Are you sure the springs are ok as they do look sad to me :cry:
Re: Prop question
Post by Jordi » Sun Jan 13, 2013 4:31 pm
That pics mine. Runs fine like that. No vibrations. I've done a few hundred mile since i fitted those springs including a hard 50mile of greenlaning and its running like a dream. Only thing i may do is have prop extended spightly.
Everything is lined up properly, i've had it at 60mph on the motorway, no knocks no vibes.
felstmiester
Re: Prop question
Post by felstmiester » Sun Jan 13, 2013 4:32 pm
:er:
dazerede
Re: Prop question
Post by dazerede » Sun Jan 13, 2013 4:33 pm
umm ye them springs do look sad there werse than mine (once my zook has a mot and insurance then it will have new springs once i can afford it ) :mrgreen:
get a new set of rascal springs that would make the rear body go up and it will straighten the prop i think
