Question *REV counter*
just wired up the 1600 vitara SPI limp into the sj. Is there a way for the standard sj rev counter to work with the vitara engine
- Edweird
Re: Question *REV counter*
I would guess yes, but I'm not sure.
Brown (possibly with white tracer) to coil negative as far as I'm aware. I.e. the same way it was wired up before.
I didnt do the wiring so wasnt sure, any pics or how to. Would I have to trace the wire back to the ac ult gauge on dash
I would imagine there will be a brown wire hanging out of the loom near the coil still
im with you now Scottie, thanks ill start with that
I think I rember seeing the wire you talking about from the sj wiring. What do I attach this wire to for the revs to work
Coil negative pretty sure there's a noise suppressor that should be in there as well somewhere though
One of Darrell diagrams for you
- image.jpg (88.28 KiB) Viewed 6102 times
Thanks, is this the same on the vit engine with it being a injection
