Problem, Little advice
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 7:58 pm
I thought i had a rear buckled wheel until I changed wheels and the wheel still seams to be buckled. Its the rear near side wheel, I don't no if its related but i have had the sj on its side whilst railroading.
Question how can i tell if the half shaft or something else is bent. Or can anyone think of anything else it could be.
I understand it hard to
tell if you cant see it, but if you tell me how to check or narrow it down i would appreciate it
thanks Andy
trotter
Re: Problem, Little advice
Post by trotter » Fri Jan 18, 2013 7:59 pm
knackered wheel bearing?
if in doubt, FLAT OUT!
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 8:01 pm
I should have said changed that wheel bearing under 500 miles ago because it was leaking and had collapsed
trotter
Post by trotter » Fri Jan 18, 2013 8:11 pm
hmmm not sure then, sorry never come across that before.. i'm sure scottie will be here shortly
with some ideas
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 8:16 pm
Could a roll bend a half shaft when it was pulled back on its wheels
kiwizook
Post by kiwizook » Fri Jan 18, 2013 8:19 pm
I guess it could have bent it. It could have bent the half shaft itself, or the mounting for the wheels. I have heard of this, but I'm not sure how likely this is. I can't imagine bending a brake drum, So I would say to take everything apart, and check all parts if they are straight, and replace/fix any damaged parts
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 8:44 pm
Ok ill get it in parts tomorrow and go from there
Post by ScottieJ » Fri Jan 18, 2013 8:46 pm
Bending a half shaft would be pretty hard to do to be honest but possible. it's also possible that the drum isn't sitting flush/true on the halfshaft flange, take the drum off, chock the front wheels, jack the back axle up and put it on axle stands, start it up and put in gear so the halfshaft spins, you'll see of the halfshaft is bent when its spinning, if its true then clean it up and refit the drum and do the same. I'm sure you'll see the problem doing that :thumbup:
dazerede
Post by dazerede » Fri Jan 18, 2013 8:55 pm
make sure u do it in 2 wheel drive :lol:
not 4 wheel drive :thumbup:
4” calmini lift kit :)
Post by ScottieJ » Fri Jan 18, 2013 8:55 pm
dazerede wrote:make sure u do it in 2 wheel drive :lol:
:lol: yeah that would be a good idea :lol:
