Handbrake cable help again
I bought this of a ebay, I'm not fitting this myself the previous owner is as he has done the MOT & welding for me in his workshop. The cable fits at the drum but not under the actual handbrake. He said it should have an attached nipple on the end of this cable, I can only guess that looks similar to the end of the accelerator cable having not seen it for myself. The cable that came does not have this style end. Any thoughts could they of sent me the wrong cable in the box, does any one have an image of the correct cable for a 1991 Samurai?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... AQ:GB:1123
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Handbrake cable help again
Using "Redlines" main website search engine it says a QH 2839
Cross reference comes up with suzuki 45068-00000.
"Redlines" ebay number for a QH cable doesn't exist
Hope this lot is some help
- gg.jpg (92.81 KiB) Viewed 8182 times
- Handbrake setup 3.jpg (107.42 KiB) Viewed 8182 times
- 45068-00000.jpg (51.52 KiB) Viewed 8182 times
- 45068-00000 (2).jpg (64.57 KiB) Viewed 8182 times
If you punch BC2839 into there ebay page it bring sup the one I ordered & don't fit on the handbrake just the drum.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Only found one half decent pic
- 3012_P1010008_1.jpg (49.25 KiB) Viewed 8163 times
cheers for the help, they sent me the wrong part when we called them they didn't know there brake hoses from there lederhosen.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
I had to "Google"thatcharger wrote:cheers for the help, they sent me the wrong part when we called them they didn't know there brake hoses from there lederhosen.
- little-miss-lederhosen-costume.jpg (47.08 KiB) Viewed 8153 times
- Edweird
Normally the shirts and shorts are shorter than that on the women.
Is this cable for the sammy, the one I get sent had an adjuster at the end not that drum looking type thing.Darrell wrote:Only found one half decent pic
My cable goes underneath not inside ???
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
i have the same type as you mate also need one as mine snaped passenger rear :(charger wrote:Is this cable for the sammy, the one I get sent had an adjuster at the end not that drum looking type thing.Darrell wrote:Only found one half decent pic
so il be keeping an eye on this page mate if i thind the right part il post it here for you
I can only find listings for these type of handbrake set-up, yours don't seem to be any off them
- Handbrake setup 1.jpg (129.38 KiB) Viewed 7864 times
- Handbrake setup 2.jpg (127.53 KiB) Viewed 7864 times
- Handbrake setup 3.jpg (107.42 KiB) Viewed 7864 times
