spot the difference
- suzukisteve
- Suzuki Guru
spot the difference
ok so long story short I ordered a new caliper. it looks about right but slightly different. ive got a girling breaking system. the back looks the same but the top looks different. also the new one doesn't have two big allen bolts holding it together
- old one
- IMG-20130219-WA0003.jpg (62.71 KiB) Viewed 5949 times
- old
- IMG-20130219-WA0001.jpg (47.35 KiB) Viewed 5949 times
- different top
- 20130219_131332.jpg (2.37 MiB) Viewed 5949 times
- back looks the same
- 20130219_131339.jpg (1.87 MiB) Viewed 5949 times
pickle power!
- suzukisteve
- Suzuki Guru
Re: spot the difference
should do I guess as long as it's for a spanish sj
- suzukisteve
- Suzuki Guru
- dazerede
Where did u order it from
Do they do Asian jap ones
4” calmini lift kit
4” calmini lift kit
- suzukisteve
- Suzuki Guru
yeah I ordered it up from work mate. pretty sure I could find some asin calipers from somewhere
pickle power!
Even if they are Jap calipers I think you can just use the jap mounts.
Might be wrong, Scottie will be along to correct me if you can't
Think the new one is a vit caliper uses the same pad but piston is smaller. Possibly.
According to brakesintnational that caliper just replaces the early bolt on bridge type
- suzukisteve
- Suzuki Guru
win! I'll offer it up tonite. there is hardly any difference as the mounts all line up etc. gotta give the sliders a good clean grease up then away we go!
pickle power!
