Windscreen pillar mount arial
Ryansherwood3
Post by Ryansherwood3 » Mon Mar 04, 2013 1:22 pm
Hi i was wondering wether anyone could help, i have a windscreen pilar ariel and was wondering if anyone knows where the cable runs and has any pictures of the fitted ariel, thanks
Re: Windscreen pillar mount arial
Post by ScottieJ » Mon Mar 04, 2013 1:42 pm
The cable runs in through behind the dash, it should be lurking around under the dash where the stereo somewhere if the cable is still attached to the aerial.
Ryansherwood3
Post by Ryansherwood3 » Mon Mar 04, 2013 2:02 pm
Yh thats what i thought but there has never been an ariel on the car that i can see. So no cable.
Post by dan_2k_uk » Mon Mar 04, 2013 2:16 pm
Goes down through a hole between the windscreen and tub above/in line with the drivers side heater vent.
Post by Tramp » Mon Mar 04, 2013 3:22 pm
Is yours a samurai? Mine never had a pillar mounted Ariel, the standard one on mine mounts through the scuttle pan on the passenger side
Ryansherwood3
Post by Ryansherwood3 » Mon Mar 04, 2013 4:05 pm
Ok and yes it is a samurai. Just find it odd hows there is no previous ariel unless it was removed and repaired but doubt it.
Post by Tramp » Mon Mar 04, 2013 6:35 pm
You cant see it well but its the silver thing infront of the windscreen sticker, mine is electrically telescopic but I think standard ones were black rubber / plastic, does yours have a hole there?
Ryansherwood3
Post by Ryansherwood3 » Mon Mar 04, 2013 7:13 pm
Awww yes thats the other place i was thinking of putting one but no there are no signs of any holes.
Post by ROBBIE » Tue Mar 12, 2013 11:32 am
I wouldn't use the pillar mount one personally, they never seem to be a tight fit and let water in.
