Starting
Crisdolf
Starting
Post by Crisdolf » Fri Mar 08, 2013 9:50 am
On the Sj413 with auto choke do u just get in and turn the key ? I did hear you press the throttle once then turn the key to start ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by twiss » Fri Mar 08, 2013 10:46 am
The auto choke is activated with thermowax, so Im pretty sure you don't need to press the throttle.
Its not gonna hurt it though ;)
Crisdolf
Re: Starting
Post by Crisdolf » Fri Mar 08, 2013 11:36 am
Cheers,starter sticking a bit guess this is probly due to being stood 6 yrs ,does a 410 one fit ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by ScottieJ » Fri Mar 08, 2013 11:48 am
No a 410 starter won't fit the flywheel is further away from the mounting face on an F series engine.
I tried to make one fit a while back and failed :lol:
Crisdolf
Re: Starting
Post by Crisdolf » Fri Mar 08, 2013 12:18 pm
Dam,can they be refurbed ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by twiss » Fri Mar 08, 2013 12:35 pm
You can refurb them but not sure exactly how as I usually just chuck mitsi and bosch ones in the bin :P
Some spare parts for mitsi ones here (make sure you check the model number)
http://www.woodauto.com/Unit.aspx?Man=M ... f=M3T38981
and here
http://www.woodauto.com/Unit.aspx?Man=M ... f=M3T39981
Bear in mind though you can get a brand new one for £80 :)
Crisdolf
Re: Starting
Post by Crisdolf » Fri Mar 08, 2013 1:02 pm
Can u where , I've seen some but they over a 100 quid
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by twiss » Fri Mar 08, 2013 1:49 pm
On those pages I liked to you, you can buy the whole starter or just the bits
Just be advised these are not really suitable for 1.6 conversions
Crisdolf
Re: Starting
Post by Crisdolf » Fri Mar 08, 2013 1:56 pm
It's ok keeping engine and truck original ,thanks for the info :)
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by Darrell » Fri Mar 08, 2013 8:36 pm
The couple I've looked at with sticky starters has been nothing more than rust in the solenoid. A strip down, fine emery paper and some WD40 sorted them.
