Starting
Crisdolf
Re: Starting
Post by Crisdolf » Fri Mar 08, 2013 10:52 pm
Yeah well it's been stood for a bit ,what they like to strip down ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by Darrell » Sat Mar 09, 2013 7:28 pm
Easy enough :thumbup:
If your a little unsure you could always just clean the solenoid up and leave the rest.
Not sure if you could do that with the starter still in place :er:
Crisdolf
Re: Starting
Post by Crisdolf » Sat Mar 09, 2013 11:08 pm
Thanks bud I,ll get it off and have a go :)
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Post by Darrell » Sat Mar 09, 2013 11:53 pm
If you get the starter off and undo the link wire from the solenoid (magnetic switch) to main body and undo the 2 screws holding the solenoid on, the solenoid body will pull off. Then you can lift the solenoid plunger off the lever. This plunger should move freely inside the solenoid body and is what can rust up.
Also make sure the pinion and clutch move freely on the shaft.
Hopefully this will fix it, but it's worth a try before spending on a new one :thumbup:
sj 413 starter motor.jpg (256.99 KiB) Viewed 3863 times
Crisdolf
Re: Starting
Post by Crisdolf » Sun Mar 10, 2013 12:46 pm
Awesome will let u know how it goes :salute:
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
