Sticky 1st gear
penpontgreenwoodwork
Sticky 1st gear
Post by penpontgreenwoodwork » Sat Mar 16, 2013 10:17 pm
Hi All
1st gear on my 5 speed sj 413 is not easy to engage, I need to be stationary and usually need to double declutch to get her in. Is it the selectors or something as simple as clutch cable adjustment. All the other gears are smooth. Any thoughts?
They don't make cars like they used to!
SJ 413, tin top.
Sammy front axle.
2"? lift Springs on front, shackles on rear.
On the road
Re: Sticky 1st gear
Post by ScottieJ » Sat Mar 16, 2013 10:23 pm
These gearboxes are supposed to be pretty much stationary before you can engage 1st, I've never driven an SJ or vitara that likes going into 1st while moving.
However you shouldn't need to double clutch it while stationary, when was the last time you checked your gearbox oil and is the clutch adjusted up to remove any slack from the cable?
Re: Sticky 1st gear
Post by penpontgreenwoodwork » Sun Mar 17, 2013 7:37 am
Thanks, I havn't long had her so am still looking into things (and turning the shed floor orange!). The prop seal is weeping a bit so there must be oil (though obviously less). Will check it and the cable. Not done anything with sj gearbox's before, how do I check the oil level, is it up to the filler bolt?
SJ 413, tin top.
Sammy front axle.
On the road
Re: Sticky 1st gear
Post by Darrell » Sun Mar 17, 2013 8:49 am
Gearbox oil level.jpg (65.14 KiB) Viewed 5435 times
Gearbox output seal.jpg (81.33 KiB) Viewed 5435 times
The seal can be replaced with a 32-42-8 r23 seal which any bearing supplier should have.
As Scottie says it's normal not to be able to get first whilst still moving.
The clutch may be dragging a little so this would make it difficult and the cable adjust may sort this.
Re: Sticky 1st gear
Post by ScottieJ » Sun Mar 17, 2013 10:42 am
If you haven't had it long I'd advise giving it a complete fluid service if you haven't already, fresh gearbox, transfer box and diff oil is always a good thing :thumbup:
Re: Sticky 1st gear
Post by penpontgreenwoodwork » Sun Mar 17, 2013 12:10 pm
Will do that. Are they all the same oil, 80w90? Thanks guys
SJ 413, tin top.
Sammy front axle.
On the road
Re: Sticky 1st gear
Post by dan_2k_uk » Sun Mar 17, 2013 12:21 pm
Theres loads of info in the tech spec section of the homepage :thumbup:
http://www.suzukiclubuk.co.uk/tech-spec ... -and-types
Re: Sticky 1st gear
Post by penpontgreenwoodwork » Mon Mar 18, 2013 6:40 pm
Everything I need to know :oops: thanks. I have 5L of 80w/90 in the shed, will it matter that much to put that in, or am I just being stingy! :cowboy::
SJ 413, tin top.
Sammy front axle.
On the road
Re: Sticky 1st gear
Post by ScottieJ » Mon Mar 18, 2013 7:14 pm
It'll be fine
